afreegreek wrote:there are many grades of plywood in each species..
doug hodder wrote:Let it go for a while and see just how bad it gets. The epoxy I'm talking about is like a West, Raka, or System 3 type material. Doug
afreegreek wrote:when you bend plywood you compress the veneer on one side and expand it on the other. without actually seeing it myself it's hard to say that this is the cause but if it is and there is no delamination around the crack there is no problem other than a visible defect..
RichAFix wrote:what if you just covered up your bad luan with good birch plywood and sealed it all real good?
Sorry you are having issues.
S. Heisley wrote:So, it sat all winter without any CPES protection applied? Oops!
S. Heisley wrote::thumbsup: To be on the safe side, Alfred, I would dab a little more CPES on those new cracks before filling them with the Fill-it.
Are you still on spring break?
