Dan
Forrest747 wrote:I am planning on running a hose hook up while at the campsite to bipass the water pump to save the battery.
Dale M. wrote:I also have to think the 3/8 fill and 1-1/4 inch vent theory is hooey....
IF you are filling tank, remember water is 800 times more dense than air and it takes very little opening for air to escape....
Years ago I had a Ford van with 12 gallon water tank under it.... Always filled it (form city water) and drained it with hose adapter and valve at bottom of tank... Only had 3/8 vent fitting at top... when water came out of vent I tuned fill/drain valve off.... NEVER had a problem with blowing out tank and it was poly type.... Come to think about it, it did not have anything BUT 3/8 fitting in tank for fill and vent...
Dale
