Steve_Cox wrote:I used yellow pine for roof spars,
dh wrote:Also, I didn't mean to imply perfectly straight red oak was available at the BORG
eamarquardt wrote:As far as beams go. I don't think it matters what they are made of. If you have an interior skin and an exterior skin (say of 1/8 ply of good quality) the strenght of the beams will really be secondary to that of the skins if they are held firmly attached to the beams. As long as the skins are held in position by the the internal supports, the skins will provide plenty of ridgidity.
eamarquardt wrote:I've seen the Kuffle Creek plans and some of the things they suggest are "the hard way". I have "talked" with Halfdome Danny and the interior roof with all the little blocks is not the way "a cabinet maker" would do it. He uses a router to rabbit a notch for the beams and interior ceiling skin. Then the outer skin goes on. Seems like a lot easier (once you make a jig for your router so it doesn't tip).
dh wrote:Hey Gus, won't you be putting fasteners into the endgrain of plywood when you attach walls and spars together?
aggie79 wrote:I did something a little different by making removable roof framing using spars and a "rib" on each side. This allowed me to skin the inside of the ceiling (and apply hull liner) with the framing on the bench rather than working overhead inside the teardrop.
aggie79 wrote:Gus brings up some good points.eamarquardt wrote:As far as beams go. I don't think it matters what they are made of. If you have an interior skin and an exterior skin (say of 1/8 ply of good quality) the strenght of the beams will really be secondary to that of the skins if they are held firmly attached to the beams. As long as the skins are held in position by the the internal supports, the skins will provide plenty of ridgidity.
Even though I used poplar for the spars, it really doesn't matter what you use if it is wide enough to glue/fasten the roof and ceiling skins.eamarquardt wrote:I've seen the Kuffle Creek plans and some of the things they suggest are "the hard way". I have "talked" with Halfdome Danny and the interior roof with all the little blocks is not the way "a cabinet maker" would do it. He uses a router to rabbit a notch for the beams and interior ceiling skin. Then the outer skin goes on. Seems like a lot easier (once you make a jig for your router so it doesn't tip).
There are many ways frame and skin the roof and ceiling. Steve Frederick's method creates a ledge for the ceiling skin and spars. I did something a little different by making removable roof framing using spars and a "rib" on each side. This allowed me to skin the inside of the ceiling (and apply hull liner) with the framing on the bench rather than working overhead inside the teardrop.
Here is a picture of the roof framing (upside down. The diagonal strips are temporary to keep things square.)
This shows the inside ceiling plywood being installed.
And this picture shows the hull liner installed.
Larry C wrote: I too have been trying to find a good method for attaching spars and inner skins. I like Steve Fredricks method, but incorporating it into my laminated perimiter won't work. I don't quite get Half Dome Danny's method, but my perimeter laminations are only 1.5"deep so I don't see how a rabbet would work for my 1.5" spars. Maybe I just can't picture it.
eamarquardt wrote:Larry C wrote: I too have been trying to find a good method for attaching spars and inner skins. I like Steve Fredricks method, but incorporating it into my laminated perimiter won't work. I don't quite get Half Dome Danny's method, but my perimeter laminations are only 1.5"deep so I don't see how a rabbet would work for my 1.5" spars. Maybe I just can't picture it.
Lottsa good ideas flowing!
Larry C, I like your perimeter laminations.
1) What did you use as far as wood and glue?
2) What is the height (when the wall is upright so we're clear) of your laminations and the thickness (in the horizontal direction when the wall is upright?
3) What are you planning to use for the the exterior skin and are you going to have an interior skin?
4) I think Danny's method might work for you depending on the dimensions of your laminations.
Gotta help #2 son with his Baja Bug radiatory right now but if you post the dimensions of your laminations, later I'll make a sketch or two and post them so you can see how it works.
Gus
Larry C wrote:Aggie79,
However, your method looks like it could work for my build, especially for my basement construction, as I want to build a modular (mostly finished) unit that can be quickly assembled in my garage.
It looks like your side ribs are narrow ( maybe 1/2" X 1.5" wide) plywood. Did you have any problem with spring back when you attached the skins? I have a 5' span and wonder if just 2 narrow strips of play will hold it's shape??
I suppose I could make 2-3 separate shorter panels with shorter ribs to help prevent spring back.
Here's the profile I need to follow:
eamarquardt wrote:Here is a sketch (forgive my rough drawings) of the "plan".
