re: gussets ... I'd rather have the extra margin of rigidity ... just my preference ... been using them for 50 years ... Absolutely no argument about the skin strength... Maybe I was just thinking too light !!!
diagonal braces or corner gussets can add some strength to skin/frame panels.. it all depends on the direction the stress is applied. they say leaving screws in doesn't add anything either but it does.. it stops a failed glue bond from getting bigger. a gusset can help prevent that failure by giving something other than the glue joint to take the stress..GPW wrote:Quote: "saying particle board is crap just shows you don't know squat.. " ... Hmmm??? Perhaps !!!Not the first time I've been told that !!!
afreegreek wrote:plywood this and particle board that.. bla bla..
there's many different types particle board just like there's many kinds of plywood.. saying particle board is crap just shows you don't know squat.. there is WATERPROOF particle board, as well as many different densities, glues, and wood fibres to choose from.. there's a few that would be just fine for building a TD out of.. and a few that are not.. just because it isn't at Home Depot doesn't mean it doesn't exist. try thinking outside the big box stores..
afreegreek wrote: diagonal braces or corner gussets can add some strength to skin/frame panels.. it all depends on the direction the stress is applied. they say leaving screws in doesn't add anything either but it does.. it stops a failed glue bond from getting bigger. a gusset can help prevent that failure by giving something other than the glue joint to take the stress..
right! that's the million dollar question.. are the skins properly bonded to the core? well, most people are not going to get a good bond to foam core. unless they get some proper foam, prep it properly, get the correct adhesive and put it in a vacuum bag to laminate it all together.. most people are going to but XPS foam and a few sticks of solid wood to build your basic foam filled, plywood clad stud wall. in that case gussets will ad plenty..kennyrayandersen wrote:afreegreek wrote:plywood this and particle board that.. bla bla..
We are not worthy… There may indeed be some exotic particle board out there that you could use, but I guarantee it will be heavy, and it likely won’t be cheap. There are so many good, relatively cheap materials to build with; I can’t see too much reason to go gallivanting off on a quest to find the grail, so to speak. Big-box = availability.afreegreek wrote: diagonal braces or corner gussets can add some strength to skin/frame panels.. it all depends on the direction the stress is applied. they say leaving screws in doesn't add anything either but it does.. it stops a failed glue bond from getting bigger. a gusset can help prevent that failure by giving something other than the glue joint to take the stress..
In a composite panel the skins react the loads and the core transfers the shear between the facesheets. Unless the skins are woefully undersized or you have a complete bond failure (if that happens you got a lot of problems), the diagonal braces will only affect the stiffness insomuch as they change the overall core stiffness (G13, G 23 terms in the stiffness matrix). It’s not that they won’t affect it, but why bother – the skin/core combination is rightfully sized to react all of the structural loads. As Andrew [rightfully] points out, we only need to make accommodations for local attachment loads (local load introduction) which can be accomplished with either buried 1X1s (or so depending on the design) or really the way it’s done is with inserts, which could be, depending on the applied load a 2 inch circular plywood disk the same thickness as the core. The internal gussets or ‘stringers’ /sticks are not needed – they’re put in there to make us feel good about it.
Last year I worked on an 18 foot long helicopter cowling that was made from very light-weight honeycomb (1.8 and 2 Lb per cu. ft. core and graphite, but for a wee bit of weight fiberglass could have sufficed. The thickest core was 1 inch thick, but much of it was only a ¼ inch thick! Except for local load introduction areas, there wasn’t anything buried in the sandwich. For local areas there was either potting compound (solid epoxy with some fillers), or inserts, that were potted into the core (most of those being only 1 inch in diameter). The core you get at bigbox is about the same density, but around ½ the strength (it’s OK, we just won’t drive the tear faster than 150 mph!). I think most people would be quite surprised how strong 2 layers of fiberglass on either side of some foam core can be. The only caution is that when going this light-weight care has to be taken to make sure that the facesheets stay attached (like poking regular small holes in the surface of the foam core etc.).
For most people it might be a bit easier to use the 1/8 ply over the 1 inch thick core than it would be to work with the thin skins and since the plywood has a lot of thickness it actually quite a bit stronger in compression than the thin fiberglass. Still, the fiberglass is going to be the lightest solution this side of graphite ($$$).
diy4life
Hi
I was at a show recently and came across this caravan...
Apart from the axle, wheels and ball joint it's all wood and coated fabric...
afreegreek wrote:
waterproof particle board is no more expensive or heavy than an equivalent size sheet of baltic birch.. it's made of long strand pine particles and phenolic resin glue. it hold screws very well, even in the edges and... it's water proof.. I wouldn't use it but that doesn't confirm the wives tale that particle board is crap. some is, some isn't. just like plywood, foam, and core-bond.
diy4life wrote:Can you help by suggesting any more search keywords?
S. Heisley wrote:
However, knowing how tight my bench beds are at 5'1" wide, I can't imagine how they got two cots and an aisle in that one.
Shadow Catcher wrote:Filon composite panels.
