My needs revised
Postby Miriam C. » Thu Sep 02, 2010 1:11 pm
ebonbetta wrote:I was more ay risk from silacosis <sp> when I was building aircraft. Or maybe boriliosis. But I spend a lot of my time staying out of the dust. and setup so the wind blows it away from me. I enjoy the heat more than the cold. The djd(Degenerative Joint Desease) in my shoulders and neck hurt less. As for lifiting I can get help to lift if I need it.
Biggest problem in the desert is ffinding shade that will not blow away.
The high desert is noted for its wind.
The drywasher only draws about 3 amps max.
A Kelty shelter or even a bat wing tarp might be easier to keep to the ground than
BAT WING CLICKY
CAR TARP
Postby ebonbetta » Thu Sep 02, 2010 5:01 pm
512 watts / 120 volts = 4.26 watts........my 1200 chugs along making 10 watts So I'm guessing it might work. ? Though I would limit what else I use with my set-up.
ebonbetta
Postby GPW » Fri Sep 03, 2010 5:55 am
512 watts / 120 volts = 4.26 AMPS
Postby ebonbetta » Fri Sep 03, 2010 12:00 pm
yes, I opped. I thought amps and wrote watts again.
I think my oldtimers is showing. It comes from watching my mom too much.
I'm 54 now .
Which is kind of young to be disabled but heck. I did not choose to get hurt.
ebonbetta
