Classic Finn wrote:Greetings Grant or Gage or... What is the cause for the torn aluminum and scrapes inside of the hub area (wall) ? When we tore down the kits we found this on both tears? Is it due to the walls swelling or coming apart or is the wall too close to the axles hubs?
Is this somthing I should be worried about?
Do I need to build the floor a little narrower?![]()
grant whipp wrote:Classic Finn wrote:Greetings Grant or Gage or... What is the cause for the torn aluminum and scrapes inside of the hub area (wall) ? When we tore down the kits we found this on both tears? Is it due to the walls swelling or coming apart or is the wall too close to the axles hubs?
Hiya, Heikki!
Sorry ... been kind of busy ......!
On the tan KIT, it probably has to do with the walls separating from the floor ... or, there's a little "slop" in the bushings of the axles.
On the other one, it probably has everything to do with the dropped-axle on springs ... when you hit a bump on one side of the trailer, it shoves that side of the axle up and against the body.
Depending on how bad the tearing is (how deep), how much the walls have separated from the floors, and whether or not you want to spend the $$ to re-build the axles on the tan KIT, you might think about narrowing the body by 1/4" to 1/2"
As always, my Friend ...
CHEERS!
Grant
