Measure twice cut once. just make sure the measurement is OK
Postby Arne » Sat Jul 09, 2005 5:39 am
I converted a van to a camper one time. Measured for the side window, cut it perfectly... went to install the window and found I had cut a rectangualr hole and the window had rounded corners... each corner had a clear view from inside to outside.....
I cut a frame from 1/2" ply, stained it and mounted it on the outside between body and window... looked pretty good... and saved my butt from a lot of rain on trips....
If I had the problem that originated this thread, I would have done the same thing, made a little frame and gone with it, unless the piece that had to be recut was small.
Often, I'll slip the tape 10 inches so I start on a '0'....
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby TRAIL-OF-TEARS » Mon Jul 11, 2005 7:57 am
arnereil,
Nope I just refaced the whole piece (16"x 16"). Now that I have one coat of varnish on it it looks better than before. It was a bit of a pain but I think it will work.
Steve J.
Home built Camp-Inn clone.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
