Solid walls and wiring
Postby doug hodder » Tue Dec 28, 2010 8:46 pm
I ran the bulk of the wiring through the roof spars, where I wanted a porch light, I drilled down through the end of the plywood as far down as I wanted the light 5/16" bit, then drilled 90 degrees to it from the outside. Fished the wires through then sealed. Same thing on the clearance lights on the bottom as well. No wires to hide, just leave an extra loop of wire up in the ceiling in case you need to replace a light or pull some more wire in the future. Doug
Postby toypusher » Wed Dec 29, 2010 7:11 am
OK, My suggestion here. First off, I have insulated walls and ran wiring through my spars and then down the inside of the walls.
However, if I was to use solid walls, I think that I would route out a slot for the wiring and put an insert in the slot afterwards, like was suggested by several others here. If you plan ahead well enough, the insert could be a contrasting wood and you could route the wire to make it an interesting design also.
JMOYMMV! :)
toypusher
Images: 324
Postby Billy K » Wed Dec 29, 2010 12:02 pm
Good stuff from All!!
Bob - I yaint skeered o' no stinkin' shiv'r'n.... :R
That carpet idea is gettin' more and more thought... combine it with a small plastic tube- in a router groove and a coil of wire in the ceiling ... add three beers and some nachos... I'll be campin!!!
That convertible ceiling is really cool.. given the other work arounds I've seen...the wires oughta hide themselves; outta fear... :D :lol:
Thanks all...any pics..??
"...influence is no government." - George Washington
Billy K
Postby Billy K » Wed Dec 29, 2010 4:45 pm
By the way...what kind of carpet do use Len??
Billy K
Postby mikeschn » Wed Dec 29, 2010 4:57 pm
I ran everything thru the roof. I did have to run a wire down the solid wall for the porch light. I covered the wire up with a strip of wood, that had a dado groove in it.
Postby Billy K » Sun Jan 02, 2011 8:58 am
So, if I go solid front wall and solid sidewalls; battery/tender and AC inlet plug in the tongue box....it is workable ???
Something like...
From the box, under the trailer, up in to a groove in the front wall and then into the spars ... one groove for each side and one in the middle area for the AC to get to the back. :?
Gotta Luv This SHHHtuff :lol:
Billy K
Postby PanelDeland » Fri Jan 07, 2011 6:41 pm
You could also use the groove idea and use a two piece sandwich wall.Maybe 1/2 outside walls and 1/8 or 1/4 inside.The inner wall would cover your wire and could be an A face of ply also.Just laminate the inner and outer walls together after you've run wire.
"I know the voices in my head aren't real,but they have some really good Ideas!"
PanelDeland
Postby Billy K » Thu Feb 10, 2011 10:57 pm
PanelDeland !! That's the ticket....!!
I could add carpet later, if cold walls are too much!!
Billy K
