doug hodder wrote:Ira I got your regular e-mail today and fired one back to you...I just found this post of yours...I think your best bet is to overhang the roof the thickness of your side framing....seal it up well underneath, then apply the side framing....You should be able to get wood to bend to the radius of the exterior of your trailer....Make sure you get something that has really straight grain, and no flaws...Rip it down to 3/16" or so and try to bend it...If it won't quite go..don't force it, soften it up using boiling water poured on top of it while wrapped in a blanket..or ideally a steam bending tube..Don't use wood like poplar...too soft..I know that you can get-r-dun with mohogany and that might give you the contrasting wood look you want....Just some ideas....Doug Hodder
cracker39 wrote:Scooter,
Are those little blocks going to be a permanent part of the finish or are they just tempoprary to use to curve the trim?
doug hodder wrote:Ira...did you already put strips on the roof at the edges? If not, overhang them to cover the edges of your side framing..That's what I did. My sides are 49" and the alum. is only 48. that's where I used the aluminum strap. That is what is overlapping the maple framing....The aluminum had a bead of 5200 under neath it. Also, I would make sure that you use stainless screws on your exposed surfaces....You live in Fla. and that could be an issue...also for anyone using oak and having an exposed screw....stainless won't bleed into the wood like a steel screw will, the tannins in oak can be brutal on a steel screw...I would not use the 5200 just as an adhesieve....I would use epoxy to affix the wood, and use the 5200 to seal...go easy on it as it wants to squish out and the 5200 doesn't wipe up well on unsealed wood...you'll end up with white stuff in all the grain..ps takes about 5 days to cure.....Just my experience....Doug Hodder
