by eamarquardt » Fri Jun 17, 2011 11:58 pm
dh wrote:Is this your idea of cost effective Gus?
www.drawerslides.com wrote:Availability: In Stock
Sold As: pair
Weight: 16.333lbs
List Price: $165.42
Your Price: $122.54
Your Savings: $42.89 (25.9%)
Not sure what model and capacity slides these are. "Cost effective" is in the pocketbook of the spender. For a lot of folks the ONLY consideration seems to be initial cost. Cost effective to me means in the "long run". I just spent about $10 to put a new bearing in a Makita grinder I've had for 30 years. It is reliable and repairable and has let me down once in 30 years. It wasn't the least expensive at the initial purchase but has been "cost effective" over the years. I have a couple of HF air grinders that have lasted a few hours at best but they're only $10. After you factor in the cost of your time stopping what you're doing and going to the store, they're not "cost effective" in my book. The next one I buy will be "industrial grade" and it will probably outlast me.
So, I'd choose a name brand slide, shop around for price and availability, and go for a capacity rating of about twice what I'd really expect to load it to. Also choose slides with an extension that fits your requirements. Retrofitting with heaver slides after a failure may or may not be easy and will certainly be more work than using a good somewhat oversized/high capacity slide in the first place. For a lot of the materials in a teardrop you can use less expensive materials and they won't affect the serviceablilty of your trailer. Quality slides for a cooler or burner will make your life more pleasant in the long run and will see more wear and tear than a non moving part.
I'm fortunate not to be constrained by cost. Suzy can afford what ever I want (and she's learning to get over it/like it in record time!).
"Choose wisely" (Knight in Indiana Jones movie).
Gus
