http://www.redneck-trailer.com/2009/I/I7-I10.pdf
gww25 wrote:Try to keep in mind the type of glue (or epoxy) you'll be using for the final assembly if you do decide to seal with CPES before assembly as many adhesives rely on being absorbed 'into' the wood pores in order to have proper adhesion. Many epoxy's also need to be absorbed as well. You can find more info about this particular issue of wood/adhesive construction on many of the wood boat forums. In general I always glue first and then seal as a secondary step but everybody has their own procedure based upon their unique experiences.
