absolutsnwbrdr wrote: But I doubt you'll find my teardrop floating in the Pacific Ocean anytime soon.
Yes, but it's nice to keep your options open.
As has been pointed out, plated die cast was the std for a lot of car hardware for decades. It will, though, not last forever. I just fabricated a wind wing hinge part for a 1951 Olds 88 that was plated pot metal (it broke). I duplicated it in SS and it will outlast rest of the car.
Just because you can see the screw heads, it doesn't follow that they can always be removed. If you through bolt the hardware and double nut the inside you can turn the screw head till the "warm place freezes over" and you still won't get the hardware off.
IMHO the prime consideration is strength.
Hope this helps.
Gus
