no you don't need UV protection for epoxy that is not directly exposed to UV light.. as far as I understand UV light is absorbed or diffused by most surfaces and not reflected.. try lying on a hammock at the beach and see if you get a tan on your back... UV is a very narrow band of frequency and is easily disrupted..terryjones1 wrote:terryjones1 wrote:I have used 1/2" plywood for the floor on my trailer.
I, first, coated the underside with several coats of CPES.
I, then, coated the underside with several coats of Raka epoxy.
Since the underside of the trailer will not be in direct sunlight, I figured that I would not need to provide uv protection.
Anyone have comments? suggestions? experiences?
I would like input on whether I need to provide UV protection for the exterior underside of the trailer, which is epoxy coated plywood.
In general, is there reflection of the sun's UV rays to this area?
from Wiki..
Many polymers used in consumer products are degraded by UV light, and need addition of UV absorbers to inhibit attack, especially if the products are exposed to sunlight. The problem appears as discoloration or fading, cracking, and, sometimes, total product disintegration if cracking has proceeded sufficiently. The rate of attack increases with exposure time and sunlight intensity.
It is known as UV degradation, and is one form of polymer degradation. Sensitive polymers include thermoplastics, such as polypropylene, polyethylene, and poly(methyl methacrylate) as well as speciality fibers like aramids. UV absorption leads to chain degradation and loss of strength at sensitive points in the chain structure. They include tertiary carbon atoms, which in polypropylene occur in every repeat unit. Aramid rope must be shielded with a sheath of thermoplastic if it is to retain its strength. The impact of UV on polymers is used in nanotechnology, transplantology, X-ray lithography and other fields for modification of properties (roughness, hydrophobicity) of polymer surfaces. For example, a poly(methyl methacrylate) surface can be smoothed by vacuum ultraviolet (VUV).[30]
IR spectrum showing carbonyl absorption due to UV degradation of polyethylene
In addition, many pigments and dyes absorb UV and change colour, so paintings and textiles may need extra protection both from sunlight and fluorescent bulbs, two common sources of UV radiation. Old and antique paintings such as watercolour paintings, for example, usually must be placed away from direct sunlight. Common window glass provides some protection by absorbing some of the harmful UV, but valuable artifacts need extra shielding. Many museums place black curtains over watercolour paintings and ancient textiles, for example. Since watercolours can have very low pigment levels, they need extra protection from UV light. Tinted glasses, such as sunglasses also provide protection from UV rays.
