Oldragbaggers wrote:
Larry, you say your floor is only 1/8" ply on BOTH sides, with foam. Your foam is only 1" thick? Wow, how solid does it feel when you sit on it? How far apart are your stringers?
Becky,
See my album for how I constructed the floor.
Much of my build is and will be an experiment to see if light weight boat building techniques can carry over to teardrop building. Also, I am using as much material I already have lying around, into my build. Case in point is my floor framing is a recycled picnic table that was built with pressure treated Southern Yellow Pine. about 30 years ago. This is much nicer lumber than what is available today. This is not the lightest wood for sure, but it is quite strong, even at 1" thick.
Andrew once stated that the stringers are only there to stop one (or 2) from falling through the floor, and serve little structural purpose. Its the perimeter walls that give the structure it's strength. The stringers are 16" apart and 12" at each end. The floor is for a 5' X 8' trailer. All lumber and the foam were thickness planed to exactly 1" so the 1/8" skins would be flat.The skins were glued to the foam and the wood with silica thickened epoxy.
I then added 3 oz. style 120 fiberglass to both sides of the floor. The glass dramatically increased the stiffness of this panel. I tested it by suspending it between saw horses at the ends, and then I got on it. It exhibited almost no flex. Remember this is without the benefit of the structural walls. Also, if you look at my chassis, you will see that it will offer very little support for the floor, it must be self supporting.
My inside walls will be constructed using 1/8" cedar strips with thin glass both sides, not glued to plywood, just the strip panel glued to the minimal wall framing and foam core. The framing is mostly around the doors (2) The wall perimeter framing is already super light weight. It was made by laminating Bass Wood strips. The outer skin will be 4MM marine plywood.
After seeing how strong the floor is, I am confident my walls will be strong and light. The walls will be epoxied to the floor. This joint and others will also get an epoxy fillet and tape. Spars are 3/4" X 1-1/4" recycled SYP. Roof will be single layer 1/8" Russian Birch plywood. The entire outside will be glassed.
This is just an experiment on my part. It may all blow apart going down the road, but from past experience, light weight construction can be taken much further than most think. Just look at what is being done with foamies. If you try a similar floor, remember you can always add a second layer of 1/8" ply if your not happy with the results, but if your planing a 4' wide trailer, 1/8" should work fine.
Larry C
