FLOOR DECKING/RIBBING - OAK VS. POPLAR
Postby Geron » Thu Sep 22, 2005 10:42 am
demtears wrote:
Geron wrote:
demtears wrote:Thank's for the advice guy's! next stop....... home depot!
An addendum:
As for the floor framing - not to worry too much -- you're going to bolt the whole thing to a metal chassis. Just make SURE it's SQUARE and LEVEL. This is absolutely essential or you'll be pulling your hair out later on.
Like I said: SQUARE and LEVEL. If your garage (building/ground) floor is not level, use adjustable jack stands. But GET IT SQUARE AND LEVEL. Did I say Square and Level??
g
Square and level I think that's what you said! would you build from frame up, or if you could would you build it like asianflava did. It look's like he built his tear then installed it on the frame just wondering which would be the best way!
I don't think sequence really matters. What matters is Square and level. Once you get the sides on bulkheads in and top on it's pretty much gonna stay square and level. The whole idea is so that the top doesn't run off one side and leave a gap on the other side, Doors fit w/o a gap on one side. Etc. etc.
Added a room on the the house using the porch as a floor. It had a 1/2 inch drop in 12 ft. from house to the edge. This kind of thing multiplies itself as you build upward. It's really hard to imagine, just try it once. :twisted:
Geron
Images: 173
Postby demtears » Thu Sep 22, 2005 5:00 pm
Thank's for the suggestion's, It sure is nice having all you guy's and gal's just a click away! really is pretty neat seeing everyones projects near to me. To others that are building on the other side of the world, and how adaptive we are building these tear's in huge shop's to single car garage's, under tarps to just being out in the golden sun. :thumbsup:
Darrin
demtears
Images: 26
