Tractor Supply Trailer
Postby bledsoe3 » Mon Sep 26, 2005 10:41 am
Steve Frederick wrote:After building with the body hanging over the frame, I'll never build any other way! I thought about placing the floor in the frame, but, I can't see how to fasten the walls without screws/bolts showing.
I think MadJack used aluminum angle on the inside to secure the floor and walls together. You could route the bottom inside of your walls to hang down and cover the frame. I welded some tabs to the bottom of the frame to help with shear loads. You can see them (barely) here. http://www.tnttt.com/gallery/image.php?image_id=2067
Bottom right of picture. It's painted so it's hard to see. Look for the dust on it.
bledsoe3
Images: 112
Postby len19070 » Mon Sep 26, 2005 11:53 am
I plan on notching my 3/4" side walls so the outside of the plywood and the outside of the frame are flush and through bolting them. Then I'll run my Aluminum side over the angle with a 90 degree bend in to the center fastening it on the underside. As far as moving the wheel its not a big deal, but I'll have to wait & see. What I'm really have to figure out how to cover a 48 7/8" width!!
Happy Trails
Len
len19070
Images: 24
Postby asianflava » Mon Sep 26, 2005 2:06 pm
Steve Frederick wrote: When I press on a corner, it tweaks in that direction. Do y'all think that the body will add enough stiffness?
Oh yeah, the body adds a lot of stiffness. Most of you know that I built my body first then the frame second. When I measured for the frame, I didn't account for any manufacturing tolerances (slop). When I dropped the body on it was TIGHT fit. The frame flexed quite a bit, I had to draw in the corners with thru bolts. Now that the body is on, the whole thing is nice and stiff.
Also consider the Camp Inn units. From what I understand, their frame is just a triangle. It doesn't have corners to support the outside edges of the body.
asianflava
Postby cjm » Thu Sep 29, 2005 12:46 am
how much was shipping?
cjm
Postby len19070 » Thu Sep 29, 2005 5:00 am
I don't know that there is any shipping available since these trailers come already assembeled. I think there all Local Pick-up.
http://www.mytscstore.com/default.asp
Happy Trails
Len
len19070
Images: 24
