WesGrimes wrote:Me too Chris!
If I sand it too fast, it gums up the paper and does not cut properly.
WesGrimes wrote:I am using Bondo brand $20 filler that I got at Home Depot![]()
Also, since I am playing confessions of a cheapskate, I am using sand paper from Harbor Freight...
There is an auto paint supply shop right down the street. Maybe I will go drop some cash on that better filler and some name brand 36 sand pads... It would be worth it to be over this stage...
WesGrimes wrote:I am using a 16" longboard.
Can I just cut a 2x4 to 48" and use that?
I could mount a couple of handles on it...
CARS wrote:me is money to me, so I buy fillers that cost close to $50.00 a gallon. My work suffers when I use the cheaper fillers (even made by the same brand), so I just don't use them anymore. A real good, reasonable priced filler is Evercoat's Rage Gold. Premium fillers are smoother and require less sanding in the long run because once you get the hang of applying them you will not do as much sanding.
I sand my filler first with 36 grit, then 80. You are going to seal the filler with primer, and almost all primers with the exception of the now extinct lacquer primer will fill 80 grit sand scratches with just a couple coats. If you are going with the proposed BC/CC finish, you would sand the primer with 180, 320, and 500 to finish the primer off. If you cut through the primer at the 180 stage, you are no where near straight and need to correct the filler and re-prime... start over...
TRP wrote:Wes,
How's this coming along? Just wanted to check back in and see if things are getting better.
Ted
