Chip wrote:If you are going rock hopping then ya might want to rethink the tow vehicle,, weight is gonna be an issue,,
R Keller wrote:TDI as a pull vehicle though? No need to worry about going lightweight at all! Should be able to do ~2,000 lbs. no problem while getting great mileage.
JunkMan wrote:Ours is a 2000 and I think it is rated at 1000 pounds trailer weight. The new ones do have a little more power, but I don't think they increased it that much.
JunkMan wrote:If you really want to go light weight, how about leaving off the outer plywood skin and attaching the aluminum right to the framing. This is how most factory built trailers were built before they all started using FRP. If you tear apart a factory built camper, you'll be surprised how little framing they use, and how thin the plywood and aluminum is.
arnereil wrote:I also still think a v-shaped tongue made from high quality 2x4's is doable.
