Socal Tom wrote:OK, I think I have an idea. Place a bathroom scale on your counter ( level it first). Make a prop rod that will hold the hatch at the height you want it to be. Then Put the prop rod between the bathroom scale and the hatch, do your best to put the prop rod straight up. Now the weight on the prop rod ( as read by the scale) is basically the lift force you need. Do your best to mount the lift shock so it will be straight up an down when fully extended. If it has to be at a angle you at least know what the final upwards force needs to be.
Once you have the right lift force the rest should be reasonably straightforward.
Socal Tom wrote:Socal Tom wrote:OK, I think I have an idea. Place a bathroom scale on your counter ( level it first). Make a prop rod that will hold the hatch at the height you want it to be. Then Put the prop rod between the bathroom scale and the hatch, do your best to put the prop rod straight up. Now the weight on the prop rod ( as read by the scale) is basically the lift force you need. Do your best to mount the lift shock so it will be straight up an down when fully extended. If it has to be at a angle you at least know what the final upwards force needs to be.
So I used the bathroom scale trick on mine, it indicated 67.5lbs at about where I will be mounting my struts. I ordered a pair of 40# shocks, so we will see if I got it right or not.
