alaska teardrop wrote:Tom,
Sounds worth exploring. Could you post a link to the ACM panels that you're considering? Have you had your hands on a piece or can you get a sample to experiment with?
Thank you, Fred
Fred,
I've only handled small sample sizes - 4" square or so - of the ACM material. The product is very rigid. For the panels with .020 aluminum on each side of the polyethylene core, the panel is slightly heavier than .040 solid aluminum. But, it is rigid enough that you could eliminate the plywood backing for a framed and insulated sidewall, and save construction time and weight.
Here are a few links to the product:
http://www.signabond.com/signabond_lite.htm
http://alumetsupply.com/ACM.html
http://www.nudo.com/Sign-Panels/Functional/PolyMetal.aspx
Take care,
