Tire Size
Postby igofshn » Sat Nov 26, 2005 1:30 am
Wow, I'm running a 31x10.50/15 on a 15x7 rim.
igofshn
Postby LSmith » Sat Nov 26, 2005 10:34 am
Summit Racing has several wheel vendors....www.summitracing.com or wheel vintiques....www.wheelvintiques.com
LSmith
LSmith
Postby grant whipp » Sat Nov 26, 2005 2:52 pm
April wrote:
" I am going to replace my current stock 9 inch tires off my trailer with 13 inch tires.Tire Dimensions: B78 x 13in., ST175/80D13 . I want to purchase the lil-bear standard fenders, but not sure if they will fit..the size description is 9-3/4"Wx15"Hx40"L. anyone got advice? "
Hi, April!
The original Li'l Bear Standard style fenders were designed around 78 series 13" wheel/tire combo, so you should be just fine. For referance you could go to the Li'l Bear site - www.teardrops.net/LilBear - select "Trailers" from the menu bar, then "Gallery" ... LB01 (top of the page) has 13" wheels/tires and has the Standard style fenders.
Chevy Vegas had the 4on4 bolt circle found on most comon 4on4 trailer hubs. The center hole on the stock steel wheels is a bit too small for the hub cone, but can be filed down to fit. Otherwise, any custom wheel that fit the Vega will fit the trailer's hubs.
Good Luck on your project! In the meantime ...
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
