Man, I REALLY like those. Simplicity.
On my next build –after me re-incarnation– I'm gonna do it JUST LIKE THAT.
TL
michaelrsydney wrote:And my interpretation!
I wanted a wooden prop rather than gas struts and the hatch is not so heavy that I need assistance to lift it. I found that a single prop worked ok but puts a twisting force on the sliding section so that it did not move freely in the slot. The solution was to make the support symmetrical by having tandem props. The two parts are separated by an aluminium spacer tube, which forms the running surface, through which the bolt goes.
michaelrsydney continued wrote:... The shape of the track is not critical so I simply followed the form of the TD sides.
I think it is important that the slot continues beyond the highest point of hatch opening and the allows the hatch to drop a little so that the weight needs to be lifted while pushing the prop forward to release.
drewh1 wrote:Nice one! Great minds think alike - funny - i have the same Galley light that you have, or at least very similar.
I too found that I had the slot drop at the bottom so the bolt dropped into it. Makes the hatch support feel more secure and you can't bump the support and cause it to occidentally close. Also like the way you used two supports.
