bouncing
Re: bouncing
Postby Kody » Tue Aug 27, 2013 3:56 am
I would definitely move the bracket forward. It needs to be at least another 3/4" forward, 1 inch may be too much. The professional trailer manufacturer in town sets the spring shackle so it is 3/4" forward from square . It is now about 1/4" forward so I would only move it another 3/4". You commented that you have 5 leaves in each spring, the springs on my trailer only have 3 leaves and they work just fine.
Kody
Never be afraid to ask questions here, Prov. 11:14
Kody
Images: 22
Re: bouncing
Postby grantstew8 » Tue Aug 27, 2013 6:14 am
I had an Avidflier (folding wing aircraft) and the instruments really hate being bounced when on the road to the airfield.
I considered air suspension and this is an email from Joe at Airbagit.com
"To get a soft ride, it is all about where you position the bags/brackets to achieve ride height at optimum pressure for the weight you have. I would assume very low pressure of perhaps 15-20lbs. The larger the bag diameter, the smoother the ride. I would suggest the DeNominator-II #2500 if you have room for a 6.25” diameter bag"
grantstew8
Images: 77
Re: bouncing
Postby KCStudly » Tue Aug 27, 2013 10:10 pm
I wonder if it could be axle wrap due to those tall lift blocks and under slung axle. :thinking:
Here's a common scenario: you hit a bump or pot hole and the component of the force that acts in the trailing direction (not all of the force is vertical) results in leverage on the tall block and spring over axle geometry which rotates the axle and cause axle wrap (the spring tries to warp into an "S" shape rather than compressing normally (flattening); then the spring snaps back slapping the tires into the ground violently (like wheel hop on a drive axle).
I realize it is not a drive axle, and someone is bound to argue that drop spindle axles don't have this problem, but there is a big difference in how arched leaf springs react to spring under vs. spring over with blocks.
Was it a large MC trailer intended for more than one full size street bike? 1750 lb rated springs sound stout to me for one bike, so I'm wondering how you were able to confirm the actual ratings. (Said another way, I would want to be pretty sure that I was not removing too much spring before I did it.)
Is the trailer at its final weight, or our you running around bare? (Sorry if this has been answered, I read the first part of this thread the other day and don't recall now.)
Spring ratings are not only dependent on the number of springs, they are also based on the length, width, material, heat treat, and, to a lesser degree, the amount of arch, so just because two different packs have the same number of leaves doesn't mean that the started out with the same rating.
Re: bouncing
Postby tony.latham » Tue Aug 27, 2013 10:35 pm
grantstew8 wrote:I had an Avidflier (folding wing aircraft) and the instruments really hate being bounced when on the road to the airfield.
I too had an Avid Flyer! B Model STOL N716TL! Hah! :thumbsup: Don't mean to hijack this thread.
How big are those golf cart tires? I'd guess they have something to do with it???
TL
Re: bouncing
Postby campwithme » Wed Aug 28, 2013 12:32 am
ty all for the help... ill check the tire size tomorrow...I was guessing on the spring weight so I got 1750s... But what is cool everyone I meet loves my trailer.....and 20,000 questions... :applause: :D :thumbsup:
campwithme
Images: 28
