Experience with 23 gauge pin nailers?
Re: Experience with 23 gauge pin nailers?
Postby MtnDon » Tue Jan 28, 2014 11:48 pm
Woodbutcher wrote: Senco. Great tools also.
:thumbsup: :thumbsup:
MtnDon
Images: 24
Postby prohandyman » Wed Jan 29, 2014 7:32 am
Bostich nailers here, in framing, 16 and 18 ga. Pin nailer is a Senco. All have worried flawlessly, with the exception of the 18, which kept malfunctioning. After several times in the repair shop, they instructed me to "never" oil this particular tool. Wierd...I oil all of the other tools daily.
Dan
prohandyman
Images: 785
Postby gcnettl » Sun Feb 02, 2014 1:49 pm
23 gauge pin nailers have no head on them and offer little "compression" of the joints. I would recommend an 18 gauge brad nailer. The holes won't be that noticeable at all. I also suggest applying wood glue to the joint, then nailing, and if you can get some clamps on it then that would be better. Gluing the joint will actually hold it on its own, the nails set it while the glue cures and helps you align it.
Back during the black friday sales, i purchased a set of Home Depot (HDX brand) finish nailers, 16 ga finish nailer, stapler, 18 gauge brad nailer, and a 23 gauge pin nailer. I have build a few art easels as christmas presents with these. The 23 gauge pin nailer hole was not noticeable to anyone, the 18 gauge brad nailer was only slightly noticeable. I have used the 16 ga finish nailer extensively at home putting up crown molding and hanging doors. My experience with it is that it needs a little more PSI than the recommend 90 psi to bury the heads, it needs around 110 psi. But for the price (99.00) I will not complain. A porter cable or bostich will cost almost double that for a single gun.
You can still get the set that I purchased from the HD website, same price that I paid. I highly recommend this set.
Link:http://www.homedepot.com/b/Tools-Hardware-Air-Compressors-Tools-Accessories-Nail-Guns-Nails-Nail-Guns-Collated-Tools/HDX/N-5yc1vZc2cdZ9tk
gcnettl
Postby Corwin C » Fri Feb 07, 2014 9:46 am
In my experience, pin nailers are truly just to hold parts in place until the glue dries. We recently had a master carpenter hand-craft a custom staircase/rail for a new house and he used both 23 and 18 gauge. He seemed to use the 23 for small trim pieces and where sanding would be near impossible, and always with glue. I also noticed that he would drive the fasteners in pairs at varying angles to help them hold. The 18 gauge still left enough of a mark that he was very judicious about where he placed the fasteners.
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
