lawsonpix wrote:That's the chart I got my weight estimate from. My teardrop is 4x8, most of the 4x8s on that chart weigh in at less that 1000 lbs. Unless I'm reading it wrong. is says: length times width,
4x8 = 4+8+4+8= 32
Some of my weight saving ideas:
Trailer: 1x2 channel: saves 34 lbs vs 2x2 box.
.032 aluminum skin vs .040 or .050
12 inch rims vs 13 rims1/2" floor vs 3/4" floorminimal shelving in kitchen.
No doors in kitchen.
No water storage while driving.
No doubling up on wood. ie: build the complete kitchen then slide it in.
No solid wood shelves in cabin, ie: integrate preexisting IKEA shelves into my cabin.
Good looking profile, and your goal is reasonably achieved, with careful watching of weight. My original goal was 1k lbs, but after I saw that I was already going to be 25% over (at one point), then I threw reason out the window and ended up here:
working on it wrote:
- sky's the limit for weight!.jpg (43.94 KiB) Viewed 184 times
If the weight of "heavy" trailers are usually near the median described by this formula
Heavy - Trailer weight (pounds) = 40 x Body Length (feet) x Body Width (feet)
then my build is in its own category, the Neutron Star-Class-Trailer weight (pounds) =
55.5 x Body Length (feet) x Body Width (feet). Not only did I use 3/4" plywood in my build,
angib wrote: If you don't believe plywood is made in any thickness but 3/4", you will probably build at the 'heavy' weight
but incorporated
neutronium wherever I could, to ensure that it would grip the road.
I highlighted the "normal" build weights from
angib, versus what my "abnormal" build reached. But, to do it all over again, I still would not reduce the strength of my frame or tongue at all, would still use my larger 14" wheels/tires (for many reasons, load capacity #1), and would keep the 3/4" plywood - secured with carriage bolts and Tek screws to the frame - as a floor (as the primary frame stiffener, and a solid foundation to attach to) even if I were to build with 1/2" or thinner elsewhere. Just my opinion, but the underlying structure and rolling gear are the most important.
