Hello,
Can anyone, please, direct me on specifically how to make these types of cuts for my riblets? I need specifics after ruined wood, more tools bought, and more ruined wood, and much
, and
I tried the 'bust out the jigsaw and go at it' route.
I then made a prototype from foam, transferred that into a hardboard template, bought more tools and bits, researched on woodworking forums and still cannot figure out how to make these parts with a router and template. The photo on page one of this thread shows several curved boards stacked and clamped together but I can't for the life of me figure out how it was done at once with the bits referenced in that post.
Here is my problem: the part is small ( 7" long x 2" wide at widest part of curve) and I cannot figure out how to get the template fastened to the wood, the wood fastened to a table, and still have room for the router to go around the clamps. Also, my failed foray into jig-saw land taught me that I need additional support around the perimeter of the part so that the router base has something to ride on. So now I need to clamp them together, provide support around the edge, and raise the router up above the level of the template.
I rough-cut a piece from 3/4" plywood with the jig-saw and then laid the template on top but I'm stuck here.
Alternately, how would I hold the template to the wood if I was to use a router table with a small part like this? I cant see using clamps as the table would interfere? Should I even try it on a table or would I likely lose some blood? (By the way, I started this build one day and drew first blood the next.)
Thanks for any help.
