by KCStudly » Wed Dec 24, 2014 12:24 pm
A variation on this string method is to use 3 equally thick gauge blocks. Clamp the string taut with a gauge block under each end, then slide the third block under the string at various points.
If the string is laying flat on the surface there is no way to judge a convex situation; the string will bow along with the arch and will still be laying on the surface. Whereas with the string raised above the surface the gap will get larger or smaller with variations.
My Build:
The Poet Creek Express Hybrid Foamie
TnTTT ORIGINAL 200A LANTERN CLUB = "The 200A Gang"Green Lantern Corpsmen
