weasel wrote:Rob, I'm goin' on top of the frame like Frank did his. Should I seal the or treat the bottom of the wood? And what do you suggest?
My $.02 worth....
seal the bottom with roofing tar. A 1 gallon can only costs about $5 or so.
After the bottom is sealed, you can set it on the frame and never give it a second thought.
If you want to insulate the bottom, press in some EPS after you've sealed it with roofing tar.
No need to put aluminum, filon, plywood, or any other skin on the bottom... that'd just be a waste of money, plus it would add the potential to capture water, a definite no no.
