Page 2 of 2
Posted:
Fri Dec 30, 2005 1:58 pm
by davel
Laredo,
Cindy says that it works like a toaster oven. Makes toast well but I doubt that you could really bake in it. We really like it and it works well with all three burners running. Only thing we are thinking of adding is a cast iron grill for the top.
Posted:
Fri Dec 30, 2005 6:53 pm
by bdosborn
They opened a Pro Bass Shop in Denver and I stopped by for the first time. The carry the Flamenta under a different name (but it still says Flamenta on the oven). Click
Here
to see it.
Posted:
Fri Dec 30, 2005 8:24 pm
by Ron Shaw
Thanks a lot Madjack...
I needed to see that post with all those galleys. Now all I've gotta do is make up my feeble mind as to what I am going to do.
WOW Choices, Choices, Choices.....
Outback is the same as Cabela's
Posted:
Fri Dec 30, 2005 8:46 pm
by Guy
Dear Bruce,
That Flamineta / Outback is the same onne the sell at Cabela's.
Does Flamineta make one that has a temperature control on the oven? The one shown does not regulate the temp.
Posted:
Sat Dec 31, 2005 3:08 pm
by doug hodder
Hey Guy....I'm just sketching out some plans...I checked out the Cabela's oven...it shows that there is a top enclosure and wind wings on it that isn't shown on the Bass Pro shops unit...cabelas description doesn't indicate anything about the top cover though, so I don't know if the Cabelas top cover is an option or not...it doesn't indicate that it is extra...both stoves are the same price.......Doug
Posted:
Sat Dec 31, 2005 5:31 pm
by mexican tear
Guy
I have not been able to find a Famineta type stove with a temp control. My wife says that it works OK if you do what Dean did and just drill a hole in the side and put a thermometer (turkey cooker type) in the side and watch the temp. Once you get the valve set right for the ambient temp, it kind of goes along fine.
kai
Re: Outback is the same as Cabela's
Posted:
Sat Dec 31, 2005 7:13 pm
by Steve_Cox
Guy wrote:Dear Bruce,
Guy,
I just got my Outback from Cabela's. It has a control valve and an oven thermometer that hangs inside the door window on the rack. I checked the thermomometer and it was more acurate than the high end GE range oven in the house. Found the GE range digital readout was off by 20 degrees but the outback thermometer was right on. The outback was pretty easy to control the temp once it heated up. Baked some pretty good biscuits on the workbench too!!
Posted:
Sat Dec 31, 2005 7:55 pm
by doug hodder
Steve....does the Cabelas unit have a cover and end wings as pictured on the Cabelas site....info on the stove doesn't mention it...and it's the same price as the Flamenta....thanks in advance...Doug
Posted:
Sun Jan 01, 2006 9:46 am
by Steve_Cox
doug hodder wrote:Steve....does the Cabelas unit have a cover and end wings as pictured on the Cabelas site....info on the stove doesn't mention it...and it's the same price as the Flamenta....thanks in advance...Doug
Mine dosen't have that cool top and wings, but when I ordered it, the picture in the on line catalog didn't have them either. Must be that they have upgraded and for the same price too.... Just my luck, got last years model. Think I'll give Cabela's customer service a call and tell them my friend Doug pointed out how I had been slighted.
