Re: Sandwich Skeleton Questions aka Getting Meat Off the Bon
Posted:
Wed Mar 07, 2018 11:45 am
by eodmike
I think the "scary" part for me isn't the application of the fiberglass. Its the sanding. It seems tedious and sounds like a lot of the time on the kit is sanding and reapplying varnish? Friz would have to chime in since he built it but it seems like you get the shape done really quick then spend tons of time sanding and painting varnish on.
I don't know I have the patience for that.
Posted:
Wed Mar 07, 2018 11:53 am
by tony.latham
eodmike wrote:I think the "scary" part for me isn't the application of the fiberglass. Its the sanding. It seems tedious and sounds like a lot of the time on the kit is sanding and reapplying varnish? Friz would have to chime in since he built it but it seems like you get the shape done really quick then spend tons of time sanding and painting varnish on.
I built a cedar strip canoe years ago. After the fiberglass/epoxy was cured, I applied a high-quality marine varnish without any sanding. I put a coat of varnish on it about every five years and it's in fine shape.
I'm considering my fourth teardrop build, unlike the first three that were aluminum clad, this one will be fiberglassed and covered with Monstaliner.
Posted:
Wed Mar 07, 2018 4:05 pm
by swoody126
YES SMALL BATCHES
and use auto body shop/Bondo squeegies
BE FRUGAL don't slather
once the initial lay-up has set then you can do nice thin hot coats to fill the weave
sw
Posted:
Fri Mar 09, 2018 9:51 am
by JeepinPete
You can avoid 90% of the sanding by using cabinet scrappers instead.
Pete
Posted:
Fri Mar 09, 2018 5:53 pm
by Esteban
Posted:
Wed Apr 25, 2018 8:33 am
by NorthEGPhoto
Kind of off topic but I wondered, I see most people seem to use plywood for their skeleton, but i've been looking at OSB for my build, since I'll be finishing the outside with 1/4" plywood anyhow. It shouldn't be exposed to the outside.
Any problems using it? it is quite a bit cheaper and AFAIK every bit as strong.
Posted:
Wed Apr 25, 2018 10:34 am
by tony.latham
NorthEGPhoto wrote:Kind of off topic but I wondered, I see most people seem to use plywood for their skeleton but i've been looking at OSB for my build, since I'll be finishing the outside with 1/4" plywood anyhow. It shouldn't be exposed to the outside.
It's my belief ––some will disagree–– but OSB is a poor choice for anything in a camper. If it is exposed to
any moisture, it'll swell and never recover. There's a reason that the thank-you-ma'am-RV industry uses the stuff: It's cheap and will
generally make it through the two-year guarantee.
Even if you could ensure that zero moisture enters your wall in the course of the campers lifetime, the adhesive used on OSB is a challenge to get a lot of glues to adhere to, unlike bare wood.
Posted:
Wed Apr 25, 2018 1:40 pm
by swoody126
DITTO Tony's feelings STRONGLY
and the stuff is measurably heavier and
doesn't hold fasteners worth a D..n!!!
your windows might hold well enough BUTT your door(s) and hatch lid will IMHO be in double and 1/2 jeopardy :-O
WHEN those hinged appendages wonkify the screw holes the water damage begins w/ a soggy bang
just this ole geezer's 2¢ worth
sw
Posted:
Wed Apr 25, 2018 2:09 pm
by Zomby Woof
OSB also comes with a weight penalty, which may or may not make a difference based on what you're building.
I can get a fair bit of OSB for free but after looking into it I decided to pay the extra bucks and go with plywood - but now I'm thinking foam
Not sure where you are in Ontario but it is possible to get better quality plywood for less money than the box stores. Locally we have
http://www.bcwlumberandplywood.com/
Posted:
Thu Apr 26, 2018 8:00 am
by noseoil
3/4" plywood for walls is ok if it's thoroughly skeletonized. You will need a light, strong framework to be under the 1,000# rolling weight you need. That's the frame & panels you need to build with & a skeletonized floor system as well.
3/4" ply for cabinets is way overkill, 1/2" with thinner face frames (1/2" solid) or no face frames at all is better. Use the side-walls of the build for your outside cabinet panels. Just make sure you have a web at each fastening point (lights, hinges, panels, bulkheads, cabinets, etc.)
.040" aluminum is ok for durability, just remember it's about .57# per square foot, or on a 5X8 build it will add about 75# with moldings & fasteners.
A good foam mattress will be about 50# so think weight here also. It's something you need to be comfortable, so choose wisely.
My build was too heavy once I added so much "extra" stuff to it (solar, group 27 battery, 110v, stereo & speakers, TV, sound bar, bluray player....) The frame was over 500#, so that was bad to begin with, but it's still solid as the day it was built. 5X9X4' tall @ 1660#... Just sayin' be careful!
