Re: Seeking window latch that pulls tight
Posted: Mon May 11, 2020 11:13 am
Tomterrific wrote:D.D.
I think I understand now. The window is in a door frame? The window is almost the entire round frame?
Interesting that I had the same idea for a homemade awning window. Hinge at the top with a 'stick' to open and close. In my design the stick would be metal so much studier. I figured the hanging weight of the stick would hold the window closed. Also, the stick and its hinge at the window would be adjusted in length to hold the window closed tightly. A steel rod for a stick and a neodymium magnet to hold the stick should work.
So without completely reengineering the window holdout perhaps just a rebuild with steel parts will do it.
Tt
Wow, what a cool idea! Yes, your understanding is correct. Now I need to look up neodymium but I get it. Thanks for the thought you put into this. Love the idea, need to see what's available.
