by cracker39 » Wed Mar 08, 2006 12:27 pm
After another trip to HD for more sealant, adhesive, and fender washers, and a couple more hours on my back underneath, my bottom of the floor is done. Did I perform overkill again? Could be, but I am satisfied that it should retard moisture.
I coated all seams, joints, and exposed foam edges with the poly sealant. All cutouts where my floor bolts protruced past the foam have been treated with Great Foam sprayed in the openings. Finally, I put some screws with fender washers in a few places to make sure it doesn't fall out. I had two pop up campers, one tent top and one Coleman hard top, and both only had undercoated plywood on the bottom. It never occurred to me to put anything else under it. So, mine, and most of the trailers built here, have more than many manufacturers put under their floors.
I didn't buy the Sikaflex or 3M 5200, but got some cheaper PL polyeurothane window, door, and siding sealant with a 50 year guarantee (like I'll be around 50 years from now to make good on it). Now, finally, I am ready to take it to the "work shop", such as it is, to start putting it together. I'll start ordering and collecting the electrical stuff so I'll have it to integrate with the skins and insulation.
