by cracker39 » Mon May 15, 2006 7:00 am
I guess I'm just hoping what I did and will do will hold up and keep moisture out. I don't think the moisture buildup inside will be sufficient to penetrate my vinyl floor and the varnish on the plywood enough to cause a problem in the wood beneath. I'm much more concerned with moisture penetration from below.
I put the Gardners roof coating on my floor bottom before I put it on the frame (so it's coated right up onto the top of the frame). Then, I installed foil-backed insulation and sealed all the edges with poly sealant. Before I am completely finished with the TTT, I'll finally have to get on my back as I want to put the Gardners coating on the foam to make a better seal and give it some protection.
But, I agree with Ira. It's not bad to work with, unless you are laying under where you are working with it, and even then, it's thick enough that it doesn't tend to drip on you. Before I do that last job, I'll pull the trailer wheels up onto stacks of lumber to get it higher to make the job easier.
