Finally, work done
Postby Miriam C. » Sun Jun 04, 2006 11:37 pm
doug hodder wrote:Miriam...in response to a way earlier post regarding tightening bolts...without a "guy" or a compressor...use a "cheater" pipe on the ratchet/breaker bar handle....an extra 18" or 2' will make you invincible....just slip it onto the handle and wrench away...however, a ratchet can be broken doing this...I never have...just my user beware warning....just an idea, but you may have thought about that....Doug
Well Doug :lol:
You are right on all counts. But to do this a person would have to take the axle off and turn the trailer over cause the ground is too tall. I was going to do it that way but Mike got it first. He actually had to pull not push and used a straight bar cause it was longer. Really not something I could do.
I did wonder if a hammer wouldn't knock the bolt in then just screw the nut on. They were too expensive to play with so I let it go. 8)
Thanks for the advice.
Miriam
Postby Miriam C. » Mon Jun 05, 2006 1:03 pm
PaulC wrote:Hi Miriam, Sounds like you have an earth problem with power leaking through. Make sure all earths have a good contact to the frame and that the earth lead on the vehicle is the same.
Cheers
Paul :thumbsup:
:oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops:
Well the van is wired and the cheapy clearance lights are now really grounded. See in my efforts to not have rust I drilled all holes, primed all holes 2 times, and enamelled all holes 2 times. The cheapy clearance lights ground through the screw, which I intentionally got slightly small. NO metal to metal on either one. :duh:
Thank you Paul for the sage advice. I will try to not be anal about rust in the future.
Miriam
Postby PaulC » Mon Jun 05, 2006 5:37 pm
Hi Miriam, Here's a tip for your next build :lol: With my lights I've taken the earth back to an earth block so that all lights/lamps earth out at one point. If I have an earth problem, such as yours, all I need to do is go to one point to check. Now if the wire comes away at the lamp :? :?
And there is nothing anal in worrying about rust.
Cheers
Paul
PaulC
3rd Teardrop Club
Images: 36
