Re:
Posted: Sat May 18, 2013 10:25 am
Jim Marshall wrote:Doug, I used a bicycle intertube behind my Paino hinges and it doesn't leak a drop so far.
or t n ttt for short (tnttt.com)
https://www.tnttt.com/
burlesot wrote:I got my piano hinge on this past weekend. I used butyl tape under the hinges and am planning to install a rubber 'gasket' over the top of the hinge too. Is a bike tire tube the best option for this?
Thanks,
Todd
p.s. I plan to split the tube, mount two strips of aluminum to 'hold' it down. However, one question is should I put a strip of 'wood' under the strips of aluminum to allow the screws to hold onto something? If so, I guess I'll use butyl tape again to cover the aluminum strips so that I don't get any leakage through the screw holes.
Fyddler wrote:I'm cheap, that's the only reason for me!
