Wish me luck
kerryd wrote:Danny , you did good ! I'm so glad you stayed away from Harbor Freight. Hobart is a good , good welder. That machine will last you 20 years . I have the same hood . You won't have any problem learning to weld . Just get comfortable and have a steady hand . It like you would be drawing it on a piece of paper. And if you blow some holes ,thats part of it .
The only thing I see in your picture I wonder about is the spool of aluminum wire . Are you going to run Argon ? It's very , very hard to push aluminum wire . With steel you should runnig .023 or .025 wire . Back to the aluminum . Most mig welders for aluminum are either push pull , pull , or gun type . If you do try . Your lead will have to be as stairght as possible . Like tied to a 2 by 4 .
For your steel wire , acouple of good brands are Filler Metals , Haris ,and Lincoln-SuperGlaze. They may be alittle more but good wire helps .As time goes on you might want to move up to argon,CO2 mix.
I trurly thing you made a good choice . If you use a cord , use the biggest one you can find. And don't go over 100 feet.
Good luk to you . you'll do good Kerry
sdtripper2 wrote:Danny:
I have been following this thread with interest.![]()
Can imagine your creativity will move to the next level of self-sufficiency now.
What are your plans for your next build or should I ask when have you
contemplated moving on to #2
Look forward to watching you breathe life into your new creation.
PS:
What model do you have?
Handler 125 /125 MIG and H-9 Gun
Or
Handler 125 EZ and H-9 Gun
doug hodder wrote:Danny...have fun with the welder..I've had good luck with a previous Hobart....and you are so lucky to have a lady in your life that encourages your projects......now go have some fun and cook up a new tear!!! So when is it going to be done? PS...gotta grinder? doug
You say your unit came with a 2003 owners manual?:thinking:
Wonder if there is any difference in the manual from 2003 to this later revision?
Most likely just a printing date.
Here is a pdf file of the 2006-8 owners manual for your
Handler 125 /125 MIG and H-9 Gun:
http://www.hobartwelders.com/om/0900/o947d_hob.pdf
Safety Guide:
http://www.hobartwelders.com/pdfs/ms199776b.pdf
Welding 101
(Good picture examples)
http://www.hobartwelders.com/techtips.html
halfdome, Danny wrote: I need to study why you need to change the polarity with different wires so I'll be doing some more grazing in welding stores/departments. The salesman overwhelmed me with so much tecnical stuff yesterday that my head was swimmingby the time I walked out the door.
Got to get back to doing what I do best, making things out of wood products, (time to go to work)
Danny[/color][/b]
