How to screw up a teardrop
Postby Keith B » Tue Mar 20, 2007 3:01 pm
Poly remains soft for about 3-5 days if under 70 degrees... Enamel can remain soft for over a week without hardner and also pending temperature. I don't know how either would dry over kilz - that's a new combination. Kilz is more of a blocker than a primer in my experience. I've always used a true oil primer for enamel paints w/ hardner. Call the store and see if he has a chemical stripper for that paint.
Keith
"Work and work and do your best! Paint and putty will do the rest!"
Keith B
Postby critter » Tue Mar 20, 2007 3:03 pm
Hey Guys,
YUP!!! got a bunch of 500watters on my boat for bowfishing.2 more sets in the shop.Now i gotta pump up the tires on the boat and fire up the generator....Good idea Thanks!! 8)
critter
critter
critter
Images: 54
Postby angib » Tue Mar 20, 2007 6:56 pm
Remember to let the whole job cool down for several hours after you've switched the lights off - they do make good 'local curing ovens', but hot paint tends to be soft paint and that won't sand well. Let it cool and it'll get harder and so sand more freely.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby doug hodder » Tue Mar 20, 2007 8:44 pm
Heat gun and a putty knife works well also...Doug
Postby critter » Mon Mar 26, 2007 9:49 am
OK Guys,
5 days of sanding and bondoing done, shes slick as you can get ewith 80 grit sandpaper.Im fixing to prime it again this morning and the unscrewing of my teardrop goes on and on and on and on and i dont think itll ever end :cry:
critter
critter
critter
Images: 54
Postby critter » Tue Mar 27, 2007 9:44 am
Hey All,
Just as i figured some bad looking places showed up after priming but not that many so here we go more sanding... bondoing... sanding....priming and the never ending paint job keeps going on and on and on :? Now i know why they make the big bucks!On a scale of 1 to 10 shes a 8 right now...maybe a 10 soon..i keep pluggin away.... If i dont go nutz! :x
critter
critter
critter
Images: 54
Postby Miriam C. » Tue Mar 27, 2007 10:01 am
Good luck critter. Sanding does seem to take forever doesn't it. :cry: Just think of the nice arms you will have when it is over. 8)
