by Nitetimes » Sat Dec 03, 2005 12:46 pm
Now you got me thinkin about this car AC again. First big plus is that it's design permits piece work. Another words, if all the parts of it were used it can easily be filled after it is installed and refilled when nessesary later on, and it could pretty much be mounted however you want with a little ingenuity (of which there seems to be no shortage of around here). Now it seems like the biggest drawback is the compressor which is belt driven, so is there any way to replace this compressor with one that is either 12v or 110v. If someone could come up with a suitable replacement I think this would be the way to go. The cost should be able to be kept reasonably low (not as cheap as the window units of course but not bad) as most everything could be scrounged from the bone yard, all you'd have to do is wander around loosening fittings to see which ones hold a charge (I'd never do that!). The ideal way to get a good one would be to get one out of a car they were pulling a motor out of that they drained the freon out of and pull that one because it would make it much easier to pull all the parts.
Now back to that little inconvienience of the compressor, anybody got any ideas? I've got a scap car in the driveway with AC and no motor, let's try it out.
Rich
- Thomas Jefferson -
