Why I was having a bad day yesterday!
Postby Grid Runner Adventures » Fri Jun 04, 2010 8:47 am
I am building the roof on my camper right now. so far I have 1/8th inch screwed down and 3/4 inch strip perimeter around the top edges and spanning the joint of the ply sheets. I used titebond III to glue the strips to the joints of the plywood spanning the joint.
I have screws and titebond iii holding the 3/4 inch strip.
once I put the foamboard and the top skin of 1/8th inch the same way. will that be a good enough joint with plenty of titebond iii and screws?
or is it imperative to fiberglass the seams.
www.offgridrving.com
Follow my build of a off grid camper that is 6x8 and I will live in it for an entire year!
Google Is My College
Postby Vindi_andy » Fri Jun 04, 2010 9:22 am
For anyone else who hasnt heard of Sikaflex I can vouch for it and an equivalent product called Tigerseal. These are both trade names for what my work colleague calls "stick like s***" PU ahesive/sealers.
In the Kitcar world most of our cars are put together using Sikaflex either as a sealer where a lanel is riveted or in some cases on its own as a sealer and adhesive.
Boys never grow in to men the toys just get more expensive and more dangerous
How true :)
Vindi_andy
Images: 49
Postby Miriam C. » Fri Jun 04, 2010 9:34 am
Gridrunner, I put epoxy dams where my trim joins the top. I put mine on exactly like you are. If I had to do it again I might consider fiberglass also. It can't hurt and will certainly help. :thumbsup:
Users browsing this forum: Bing [Bot] and 8 guests
