oklahomajewel wrote:wow ... I thought it looked a lot bigger!
So the whole camper is 4x8 by about 5?
$700 is very doable? Did you just buy your pipe and such at a home store or get discounts?
And what size pipe again? Will there be any wood on the bulkhead wall or cabinets???
Sorry for the questions... I hadn't seriously dreamed of building a second one and now you've got me thinking,.....
especially for the ease of building and mostly the weight issue!!!
$700 includes the trailer kit with 13"rims/tires ...all the pipe was purchased at Lowes/home depot ..schedule 40 ,3/4"in (ID) PVC pipe...its sold in 5 and 10 ft lengths ...I bought mine in the 5 ft lengths mostly for ease of transport plus the fact that no single piece used in the construction of the frame exceeded 46 inches.You WILL use a lot of "T" fittings ,plus 4 way crosses,3 way elbows ....i'm trying to put together a plan sheet showing whats needed where etc...but I dont know when it will be finished(my CAD skills leave MUCH to be desired)
....believe it or not my original plans had nothing to do with buildinfg a tear/TTT but simply a small lightweight enclosed utility trailer I could pull safely with my small car.I happened on this site by accident.Once I did I decided I wanted a dual purpose trailer not only as a utility hauler for carrying my R/C planes around in but also pull double duty as a camper occasionally as well.I never intended to put in a bulkhead at all as it would prevent me from loading my planes.In the back where a "kitchen"would ordinarily be placed ,I planned for a stoage area with a shelf/countertop above .This is stiil there and will be dual purpose ,not only as a work area for cooking but a work area for charging batteries etc for my planes as well.
....interior walls are planned for as well as insulation and 12/110v electric...that will be further down the road though as this is a continuing work in progress .As of right now it is a permanently erected "tent" /utility trailer and little more at this point.
.... Of course with the flexibility offered working with PVC pipe designing in cabinet supports and /or cubbys etc is allup to you.One thing though ....you will be creating a lot of white sawdust cutting pipe ,if you don't already have an power miter saw/chopsaw ...get one ,otherwise one of your arms will end up bigger than the other...
