Masonite for roofing material?
Postby TD4FREEW/CTD » Wed Jul 30, 2008 11:54 pm
found this on wikipedia, thought it was interesting. no glue, apparently. according to wikipedia, that is.
Masonite is a type of hardboard invented by William H. Mason.[1] It is formed using the Mason method, using wooden chips and blasting them into long fibers with steam and then forming them into boards. The boards are then pressed and heated to form the finished boards. No glue or other material is added. The long fibers give Masonite a high bending strength, tensile strength, density and stability. Unlike other composite wood panels produced using formaldehyde-based resins to bind fibers, Masonite is made using natural ingredients only, which makes it an environmentally friendly "green" product.
TD4FREEW/CTD
Postby bgordon » Thu Jul 31, 2008 1:45 am
mikeschn wrote:Clear penetrating epoxy sealer... I buy it here
http://www.rotdoctor.com/products/cpes.html
But over there, you might want to plan on sealing it with epoxy, or spar urethane like Len does.
Mike,
Thanks! I read the link and now I know what it is. Looks like great stuff. Pity we don't have it over here... :cry:
Barrie
Keep moving forward.
Psalm 1:1-3.
Build Journal: bgordon's 5 week cardboard & fiberglass build
http://www.tnttt.com/viewtopic.php?f=50&t=38781
bgordon
Images: 122
Postby Cliffmeister2000 » Wed Aug 06, 2008 3:38 pm
Mike,
I found this supplier in Southern Africa. I assume that would include South Africa.
[url][email protected][/url]
This is the manufacturer website
http://www.smithandcompany.org/
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby Larwyn » Wed Aug 06, 2008 4:08 pm
I may have already posted this, when this subject came up a few years ago.
Before I moved ot Kerrville I actually did not have a shop. All my work was outside or under a tarp and storage was under tarps. I had a 4 x 8 foot table which I kept level and covered with a tarp when not in use. All my sheet goods were stored on top of that table. The top of the table was 1/2 inch plywood covered with 1/8" masonite. I had both 1/4" oak and luan as well as some 1/8" oak paneling stacked on the table, some of it for quite some time There were also a few 1/4" masonite templates and such stacked along with the sheet goods. After one particular wet season most of the material on the table under the tarp became and stayed quite damp. Of all the material which steamed there under that tarp, the masonite came through in the best shape. I did not build the Escape Pod from masonite, but from what I have witnessed I do feel that masonite would be a suitable material for the purpose and would not hesitate to use it. The luan came through in okay condition too but it did suffer more warpage and seperation than the masonite. If painted or otherwise sealed they would all work out just fine.
If this involuntary test had preceeded me putting a roof on the Escape Pod there is a good chance that the roof would now be masonite.... :lol:
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Postby Hoosier Greg » Wed Aug 06, 2008 8:28 pm
[quote="len19070
Now If I'm doing a rubber roof I don't do anything, just scuff it up and laminate right to it.
Len. I'll be doing a rubber roof on my build.How did it work out for you.
Thanks,Greg.
Hoosier Greg
Postby 2bits » Wed Sep 10, 2008 9:51 pm
Well, I did it. Given the dramatic angle of the front of the profile, cost concerns, and "you're gonna seal the heck out of it anyway" in my brain, I installed masonite.
I notice that screws seemed to tear right through it, but tiny trim nails kept it in place for the glue to dry just fine... used titebond for glue and will put at least two coats of CPES on it. Just now got it on, will trim the edges after the glue dries.
Thomas
2bits
2bit Member
Postby McBrew » Thu Sep 11, 2008 10:08 am
Lookin' good! Keep us informed on the masonite. I'm thinking about doing the same thing. Looks a lot easier than dealing with lauan. I'd CPES it like you're going to do and cover it in aluminum... so it seems like it would work just fine.
-Jesse
1984 Scamp 13'
In the process of bringing it back to its former glory... if not better!
McBrew
Postby RICHARD FURROW » Thu Sep 11, 2008 12:40 pm
Gee Sparksalot, you sure did SPARKSALOTTA attention with this one! I appreciate it though because it is an interesting subject. It seems that the 1/8" Baltic Burch is hard to come by in some parts of the country. The folks that can't get it easily are all looking for an alternative. Sorry about the pun, couldn't help it!
Ricky
RICHARD FURROW
Postby 2bits » Thu Sep 11, 2008 1:27 pm
i would have preferred to get some birch like i used for the headliner, that bent very well but i didnt have the $$$ and i would have needed to take time off work to go get it too. i had a hard time getting it done at the front and i am not in love with the texture but i think it will be just fine.
Thomas
2bits
2bit Member
Postby Sparksalot » Thu Sep 11, 2008 9:23 pm
RICHARD FURROW wrote:Gee Sparksalot, you sure did SPARKSALOTTA attention with this one! I appreciate it though because it is an interesting subject. It seems that the 1/8" Baltic Burch is hard to come by in some parts of the country. The folks that can't get it easily are all looking for an alternative. Sorry about the pun, couldn't help it!
Ricky
i'm glad this has been helpful to all.
I ended up getting 4x8 sheets of 'Mahrcan birch to do the roof. From the pictures you can't really tell this. The sheets wanted to curl inward, and i wanted to let then lay nicely.
Sparksalot
Images: 687
Postby GPW » Mon Sep 22, 2008 6:19 am
You guys really need to try the poly/mineral spirits sealing trick on Masonite ... we did a sample ,two coats of a good high solids Polyurethane and Min. Spts. mix... threw it out in the yard ...rain /Gustav-Ike, no problems ...got a little dirty ,but easily brushed off ... no water intrusion , no mush...
We've been painting on Masonite panels for over 50 years now, early examples still in good shape , just a little dusty....
Postby H@nk » Mon Sep 22, 2008 4:11 pm
john wrote:I used hard board on my TD. Flexible cheap heavy stuff, but it has to stay dry. I painted it first with some kills and good exterior paint then covered it with aluminum.
no leaks please :rainy: :rainy:
Thats the same I did. I used hardboard for the roof, but putted some epoxy on it, the same stuff they use for the boats together with sheets of glass.
Old bread isn't hard, no bread, that's hard.
H@nk
Images: 81
Postby 2bits » Mon Sep 22, 2008 8:07 pm
I liked CPES personally because it penetrates all the way through so when it is done you end up with a sheet of epoxy resin, not a sheet of Masonite with a coating of sealer on top. I'm not "dissing" anyone else's method at all as I have no experience, this was just my thoughts when I chose the CPES.
Thomas
2bits
2bit Member
