Walt M wrote:Kenny the hinge is raised up 1/4" above the roof frame member so when I applied two layers of 1/8" ply the hinge and the ply are even. You can see in the pic the the hinge on the harch side is lying on top of one ply layer and the second layer butts up to the hinge on the hatch, so the hatch and roof are smooth then I covered the whole thing with 060 epdm rubber. You can't see the hinge at all,it's completely hidden. Does that help? Walt
Ah-so -- then what seals that area -- the white EDPM top?
