1/8" masonite questions??
Postby 2bits » Mon Aug 17, 2009 9:26 pm
kennyrayandersen wrote:BTW, one thing about Masonite is that it is heavy -- not quite twice as heavy as poplar plywood of the same thickness. and nearly 50% heavier than Luan. you will save nearly 40 lbs from switching from Masonite to Luan assuming 10 sheets (inside and outside). If you can find poplar plywood, you'd save around 60 over a Masonite build. I'm just not 'feeling' the Masonite. :thinking:
I think the bad that I have heard about masonite is that is water even touches it, say bye bye Jenny. So you don't let water touch it with out copeus amounts of epoxy.
What I have heard bad about Luan is that it has more voids internally which can lead to cracking during installation and moisture forming in the voids.
Just what I've read that's all, each has their con's. In a perfect financial world lay down some 1/8" Baltic Birch and be done with it! Unfortunately this is not a perfect world :oops:
Personally I used three sheets of 4x8 Masonite under the AL (4 foot sections laid sideways with 3 feet of cut offs). Makes ya wanna build a 4 foot wide I tell ya!
Thomas
2bits
2bit Member
Postby bve » Mon Aug 17, 2009 9:56 pm
48Rob wrote:
Water penetrated from a seam in the roof line and collected on the back of the Masonite and wham
If the roof leaked, it would have ruined whatever you used for a ceiling...no?
I have to agree with Rob, the only difference with the masonite was the problem (the leak) became obvious right away rather than a year later after it created other problems.
Perhaps another way of looking at it is, had the masonite not failed right away the water likely would have continued to come in and perhaps also ruined the walls too. On the pop up I tore down you could tell water had been coming in for years unnoticed, it had saturated the entire roof and side supports in the roof before it fell apart.
Burke
KISS > COMPLEX
Build threads converted to PDFs.
As of 2008-08-08 I have added more build threads to the pdf collection
bve
Images: 98
