oicu812 wrote:Does anybody know or have an estiment of what these different
construction methods wiegh per Sq. Ft. of finished wall?
Thanks in advance.
Tony.
BillZ wrote:Your average person was much thinner back then.
angib wrote:
My job takes me into people's lofts (US: roof space?) and on houses over 100 years old, loft hatches 12"x18" are not uncommon - presumably your average builder fitted through that hole back then.
Denisttt wrote:To answer tcolar's last question, someone did have a build journal of a trailer made of regular foam insulation and fiberglass on both sides. It also happened to be a pop up because he wanted standing height without the drag. Unfortunatly, I can't find the link but you should find it if you look hard enough. It was interesting because it hadn't been painted and you could see exactly what he had done. He pulled it with a Jetta if that helps.
aggie79 wrote:Denisttt wrote:To answer tcolar's last question, someone did have a build journal of a trailer made of regular foam insulation and fiberglass on both sides. It also happened to be a pop up because he wanted standing height without the drag. Unfortunatly, I can't find the link but you should find it if you look hard enough. It was interesting because it hadn't been painted and you could see exactly what he had done. He pulled it with a Jetta if that helps.
This is the link to the build thread:
http://www.tnttt.com/viewtopic.php?t=19227
Here is a link pictures of the Bluebonnet Teardrop. I've seen this one in person and it is a very nice build. They used the same glass over foam construction for walls and roof:
http://www.tearsoftexas.com/gallery/main.php?g2_itemId=673
This is a link to a trailer with sides and roof also made of glass and foam:
http://www.goldbrand.info/motorcykelhusvagn2.html
glassice wrote:I bet a $1.00 that the last one is a lot hever than they say alot
