eamarquardt wrote: The heat/cool cycle and resulting expansion/contraction can't be good for the sandwich. Not that you can't take your trailer out in the sun, but even if it was used 2 days a week that still gives you 250 days a year you can keep it out of the weather (mostly the hot sun). Doing that might extend the useful life by a factor of 3 (well beyond our practical lifetime).
Gus
kennyrayandersen wrote:I agree with most of what you said to a point. I really don't see than you are not agreeing with anything I said.. The skin needs to be thick enough that it can withstand abuse loads and some impact damage. Agreed. However, not every place on the tear is exposed to the same hazards. Agreed. As Glassice suggested – the door and the hatch are areas that get ‘abused’ more than others. The galley area would probably be more prone to things being dropped or ice chests being slid around etc. I’d also add the lower front (where things get kicked up by the car), and the underside aft of the fenders (though the fenders should catch most of it). It would probably pay to put an extra ply or two in those locations. All seems like common sense to me. Small delaminations (under a nickel size or so) shouldn’t make too much difference unless you get a bunch of them). You would want to protect so that you could drop a butter knife hilt first, but perhaps not a hatchet. Everything in life is a compromise. No such thing as a "perfect compromise" as all compromises trade one thing for another.
good idea on both..glassice wrote:When I was poorer I put 10ea 20 d nails in a 1x4 to pock holds in the foam. It work great under leaves at the door to stop thieves
eamarquardt wrote:kennyrayandersen wrote:I agree with most of what you said to a point. I really don't see than you are not agreeing with anything I said.. The skin needs to be thick enough that it can withstand abuse loads and some impact damage. Agreed. However, not every place on the tear is exposed to the same hazards. Agreed. As Glassice suggested – the door and the hatch are areas that get ‘abused’ more than others. The galley area would probably be more prone to things being dropped or ice chests being slid around etc. I’d also add the lower front (where things get kicked up by the car), and the underside aft of the fenders (though the fenders should catch most of it). It would probably pay to put an extra ply or two in those locations. All seems like common sense to me. Small delaminations (under a nickel size or so) shouldn’t make too much difference unless you get a bunch of them). You would want to protect so that you could drop a butter knife hilt first, but perhaps not a hatchet. Everything in life is a compromise. No such thing as a "perfect compromise" as all compromises trade one thing for another.
Gus
afreegreek wrote:little delams can be fixed if caught early too.. you just need to drill a small hole and inject some resin..
if you're smart, you can do it with your vacuum cleaner..
kennyrayandersen wrote:Gus -- I was slightly disagreeing about the thermal damage you were suggesting -- I don't think it is there. Of course -- how would you know what I was thinking -- since I forgot to write it down!!![]()
kennyrayandersen wrote:afreegreek wrote:little delams can be fixed if caught early too.. you just need to drill a small hole and inject some resin..
yep -- just like them cracks in the windshield!
basically you use the vacuum to suck out the air.. suck hard enough and the cavity will become a vacuum chamber.. you get some resin at the entrance to the cavity and release the vacuum.. the cavity will suck the resin into itself as it tries to equalize it's pressure with the outside pressure..eamarquardt wrote:kennyrayandersen wrote:afreegreek wrote:little delams can be fixed if caught early too.. you just need to drill a small hole and inject some resin..
How do you get a "sucker" to "inject"?What's your technique? I've done the "windshield miracle cure" several times with excellent results!
Gus
afreegreek wrote:basically you use the vacuum to suck out the air.. suck hard enough and the cavity will become a vacuum chamber.. you get some resin at the entrance to the cavity and release the vacuum.. the cavity will suck the resin into itself as it tries to equalize it's pressure with the outside pressure..
it's a poor explanation but it's the best I can do
