I did not post this to start an argument, granted water is used for the heat exchange side, like air is used on the window unit. The operating principle of the A/C cooling is the same, refrigerant and a compressor, heat pump or not. I posted a formula thats is no different than using a residential or commercial A/C formulas which has little to no bearing in a teardrop enviroment either. From one extreme to another. The low insulation R value or lack of it in a teardrop or trailer has little to no formula, way to many variables to include. I found that it usaully takes a lot of information, from a wide variety of sources, to try and figure out the way just to make it understandable. So since the intent of this was not to cause an arugment. All it was is a formula, another way to look at it, that is it.
So you didn't need to get sarcastic about it, I was not trying to be when I posted this formula. You asked my reference and I provided it, a formula I had found. This discussion of teardrop A/C has come up time and time again for years. Nothing has ever been gained or set in stone about the correct way to figure it quite out yet either. Unfortunately to many times the K.I.S.S. principle is thrown away by making it way to scientific. We are building tiny retro trailers, not the Space shuttle. Are we still friends?
