DudKC wrote:I wasn't planning on epoxying the trim into place, I was leaning more towards the caulk. I think the 4 oz cloth will be good under the trim to help seal out water. I just got back from the hardware store but they only had a package of 3M that looked real thick and it didn't say what the weight was. I found this website.
http://www.uscomposites.com/cloth.htmlWould this 4 oz cloth work well?
Should I put the first coat of epoxy on, then lay the tape down, then put the 2nd coat down, or how should I do that?
If your covering with trim, fiberglass tape will probably be easier for you to use. I mentioned bias cut strips of cloth if the seam was going to show. I would buy some 6 oz. tape which is the thinnest I have seen. Roll out the amount your going to use and with a helper stretch the tape by pulling on it gently. This will help the edges lay flat.
A method I have used that works good is pre-wet the surface with a thin coat of epoxy. Let it tack up so your finger sticks to it. Carefully roll out the re-rolled pre stretched tape onto this sticky surface, you will be able to move it around and pull it back off to get it straight, so don't rush. The tape will stay put exactly where you put it, and you can not wet it out with a roller, brush or squeegee. This is much easier for a first timer IMO.
Another method is to re-roll the prestretched tape and immerse it in a cup of epoxy till it's saturated. Pull it out when it goes clear, and let it drain back into the cup for a couple minutes. You should mask off all areas you don't want drips of epoxy to deal with later. You can now roll out the pre wetted tape on the seam. It will stay in place once you squeegee the first foot. This method is a little faster, but a little trickier getting started on the surface.
There are lots of methods/tricks on applying cloth or tape over wood. The best advice I can give is "WORK CLEAN" mask everything around the work area, wipe up spills, runs, etc. Remember one thing with epoxy: "Less is More" Just wet the cloth/tape till its saturated, squeegee it till its flat against the surface, and dull looking, not sloppy wet and shiny. It's best to build multiple thin layers, not one heavy thick one. I actually soak up excess epoxy with a dry roller and paper towels.
Larry C
