MDO Plywood and CPES?
Postby aggie79 » Tue Jan 31, 2012 12:59 pm
del690 wrote:So using this cpes stuff is way better than doing something like Thompson's water seal?
Most applications of Thompson's water seal are not top coated with paint. By their literature, you can paint over Thompson's-treated wood but only after 30 days and only with oil-based paint. That would be limiting to a lot of folks.
Postby del690 » Thu Feb 02, 2012 6:22 pm
So whats the ballpark estimate on doing a whole TD? Say a 5' x 9'?
del690
Postby del690 » Thu Feb 02, 2012 6:23 pm
del690
Postby absolutsnwbrdr » Fri Feb 03, 2012 9:56 am
del690 wrote:So whats the ballpark estimate on doing a whole TD? Say a 5' x 9'?
Hard to say. As afreegreek has mentioned time and time again, CPES isn't cheap.
I got a 2 Qt kit for about $60 - that was enough for a couple coats on my plywood skins (front curve, hatch, and narrow roof sections). As discussed in this thread, I didn't use it on my sides walls though, since they are MDO plywood. And I also didn't have a full roof to do.
I'd think that you'd need at least two of the 2qt kits to do an entire "traditional" teardrop.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby S. Heisley » Fri Feb 03, 2012 10:40 am
Del690,
It is my understanding that CPES is not sold in Canada; nor do they ship to there. There are other available epoxy products that can be purchased and used in Canada that can be used for your build. Please check with your stores or building friends nearby.
Postby del690 » Sat Feb 04, 2012 8:00 am
CPES is sold in Canada by BCS inc. It sounds like a very interesting product that I had no knowledge of up until recently. Thanks for all the help guys.
del690
Postby S. Heisley » Sat Feb 04, 2012 12:50 pm
Thanks, Del! The next time a Canadian asks where to get it, we'll know! :)
Postby del690 » Sat Feb 04, 2012 1:13 pm
Your welcome Sharon. The actual web addy is http://www.woodrestoration.net/
del690
Postby del690 » Sat Feb 04, 2012 1:15 pm
and when I say "guys" I am including both genders :)
del690
