Aluminum skin thickness?
Re: Aluminum skin thickness?
Postby halfdome, Danny » Fri Apr 06, 2012 5:26 pm
You could buy enough 4' x 10' sheets of aluminum, cut in half (4' x 5') and do a lap seam using VHB tape.
As you can see you can just tape it down (left seam) or tape & screw it down (right seam) with proper sealants.
Next time I'll just clamp both VHB taped seams for 36 hours and forget the screws.
:D Danny
Last edited by halfdome, Danny on Fri Apr 06, 2012 5:51 pm, edited 1 time in total.
halfdome, Danny
*Happy Camper
Images: 252
Postby linuxmanxxx » Fri Apr 06, 2012 5:51 pm
If you are near austin you need to brush up on your google and phone book skills ;) try westbrook metals and if you want colored aluminum contact the trailer manufacturer in waco and you can get it any length and 49" wide with a wide assortment of colors and I got it for around 9 a running foot when I bought some last year. They are Continental Cargo and look for the contact information for waco and give them a call if that width works for you.
linuxmanxxx
Images: 10
Postby Javanino » Fri Apr 06, 2012 6:37 pm
linuxmanxxx wrote:If you are near austin you need to brush up on your google and phone book skills ;) try westbrook metals and if you want colored aluminum contact the trailer manufacturer in waco and you can get it any length and 49" wide with a wide assortment of colors and I got it for around 9 a running foot when I bought some last year. They are Continental Cargo and look for the contact information for waco and give them a call if that width works for you.
Ahh.....there lies the problem young Skywalker. Tons of places have 49". I want seamless from the front to the back so I need long unlimited coils. Worth the drive or whatever. I think I may have found a place that sells 103" wide as long as you want in San Antonio but I won't know for sure until Monday.
To be continued......
Javanino
Postby 2bits » Fri Apr 06, 2012 11:52 pm
The 103' wide is typically the roof material for tractor trailers. I feel your pain though. People always post to ask "Sign shops" which doesn't exactly give any kind of results. I had a hard time finding the right search criteria myself. Focus on trucking companies and you'll get exactly what I wanted too... 103 wide and as long as you want...
Here isa quote from another thread... this is quite the common topic...
wingnut wrote:When I built mt 4X10 TD I couldn't find a local supply of sheets of aluminum long enough for the projeact. I got my long pieces from an outfit called Airpart Inc. in Kansas City , KS. They sell 5250 in sheets up to 12 long and thet roll them for shipping, so they can ship UPS. I just checked the current price of .032 4' wide is 10.95 per foot. I used one 8' sheet two 10' sheets & one 12' sheet. At the time I bought mine it came to a little over $450.00 with shipping. The increased prices of every thing I bet it would come to $500.00 today.
Thomas
2bits
2bit Member
Postby Javanino » Sat Apr 07, 2012 7:28 am
That's a good alternative Danny, hadn't been familiar with that product before.
What tool seems to work best for you in cutting .032 material. Does aluminum really cut that well with a router?
Javanino
Postby 2bits » Sat Apr 07, 2012 8:46 am
aluminum likes to melt with a router, you can get a deal that lowers the speed of the router by limiting the current, but I had thick aluminum on mine and with a fine tooth blade it cut like butter using a jigsaw which is much easier to control freehanded
Thomas
2bits
2bit Member
Postby Javanino » Sat Apr 07, 2012 9:04 am
2bits wrote:aluminum likes to melt with a router, you can get a deal that lowers the speed of the router by limiting the current, but I had thick aluminum on mine and with a fine tooth blade it cut like butter using a jigsaw which is much easier to control freehanded
Yes, that was my concern. Not to mention flying bits of metal. I'm going to invest in a pair of electric shears. I believe they'll be perfect for aluminum. The kind that takes a small chunk out that coils as you cut work great. I haven't tried the roller style, they may be better still.
Javanino
Postby halfdome, Danny » Sat Apr 07, 2012 9:24 am
Javanino wrote:That's a good alternative Danny, hadn't been familiar with that product before.
Javanino, I cut the aluminum sheet in half on my table saw with a carbide tipped 80 tooth blade.
If were me I'd use nothing less than .040 aluminum on the roof.
I've used .050 and it was easy to use even on my tight roll pan radius's.
Like mentioned before aluminum wants to melt while routing especially with a 2 flute 1/2" bottom bearing bit.
I use a 1 1/2 HP Porter Cable router & the aluminum cuts like butter with a 3/4" bottom bearing flush trimming bit with two flutes.
I have a pneumatic Harbor Freight piece of crap :thumbdown: shears and only use them on rough cut wall radius's followed up with the above mentioned router and bit.
If you have excess aluminum to play with you could clamp the sheet to a straight edge and route a straight cut.
Make sure to use plenty of masking tape as the routed chips land in the path of the router base.
It's helpful to have an air nozzle close by to clear chips.
Always wear face and eye protection. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Javanino » Sat Apr 07, 2012 10:08 am
Thanks Danny,
I have only used the shears I speak of on 26 gauge galvalume and they worked great. Have you ever tried the roller style shears? Can't find a photo but they have 2 little wheels that do the cutting. There's a name for them but I don't know what that is. I've worked with wood for the past 30 years but metal is an entirely different animal that I have limited experience with.
Love your quote BTW. Very true how many use every excuse imaginable for inaction.
Javanino
Postby halfdome, Danny » Sat Apr 07, 2012 10:30 am
Javanino wrote:Thanks Danny,
Javanino,
My only experience with shears is the ones I mentioned.
I wonder if those two little wheels would disfigure aluminum.
What I don't like about my Harbor Freight shears is it's very difficult to get them to start cutting.
Once started :x they work fine, for a brief period, but stop occasionally while in the cut.
I've taken the cutter apart, lubed it all and they work better, for awhile.
I had to put a 90 deg fitting on the air intake just to get it to work as the hose gets in the way.
Some day I'll find something more suitable to do the job.
If you've worked with plam in the past aluminum is kinda the same drill.
I worked with aluminum & brass trim on high end store fixtures so I had some experience before getting into teardrops.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby KCStudly » Sat Apr 07, 2012 12:53 pm
I've always known the three finger shears to be referred to as "Kett" shears. I'm sure this is a brand name, tho. Like Skilsaw.
Postby 2bits » Sat Apr 07, 2012 10:06 pm
Not thinking about the jigsaw at all? It doesn't mater to me what you use since all the choices are good ones, but it was like cutting 1/8" ply in my opinion and you wouldn't need to buy anything new. Just cut on the back side so as not to leave any marks ;)
Thomas
2bits
2bit Member
Postby 2bits » Sat Apr 07, 2012 10:09 pm
2bits wrote:Not thinking about the jigsaw at all? It doesn't mtater to me what you use since all the choices are good ones, but it was like cutting 1/8" ply in my opinion and you wouldn't need to buy anything new. Just cut on the back side so as not to leave any marks ;)
Thomas
2bits
2bit Member
Postby aggie79 » Sun Apr 08, 2012 7:41 am
2bits wrote:Not thinking about the jigsaw at all? It doesn't mater to me what you use since all the choices are good ones, but it was like cutting 1/8" ply in my opinion and you wouldn't need to buy anything new. Just cut on the back side so as not to leave any marks ;)
I'm with Thomas. A jig saw is the way to go. That's how I cut most of my aluminum.
Postby Javanino » Sun Apr 08, 2012 7:49 am
Different strokes as they say. Personally I have found that the 3 finger style shears to be far easier to work with than a jigsaw. Particularly with thinner material. There may be better ways still. I'll post up what I think of the wheeled style cutter if I can find one to try. If it can do curves the way they say, it'll be the way to go.
Javanino
