Attaching the cab to the frame
Re: Attaching the cab to the frame
Postby Forrest747 » Wed Sep 05, 2012 1:09 pm
http://nucor-fastener.com/Files/PDFs/TechDataSheets/TDS_013_Shear_Strength.pdf
So by that measure a grade 8 5/8" pin on the hitch is 27,000 pounds and change.
A single 1/4 inch is 4 thousand and change.
Straps and chewing gum it is.
Forrest747
Cowbell Donating Member
Images: 447
Postby Bikerman » Sun Oct 21, 2012 12:29 pm
wow, I was going to use 4 disconnect pins, one at each corner, as used on my trailer hitch. Don't know the size but thought I'd put some flat bar steal inside instead of washers, run some tight fitting pipe through the wood and then trough the steal plate floor of the trailer. I wanted to be able to take the box off and still have my utility trailer. Now, I'm not so shure..... :roll:
PS. SIte seems faster to me, it works great....Thanks!
Bikerman
Postby DMcCam » Sun Oct 21, 2012 1:54 pm
Hey Steve, I have 12 3/8" carriage bolts with big heavy washers and lock nuts holding my cab to the frame, 4 on each side with 2 in the front and back. They are attached to tabs on the inside of the 2" tube frame and are about 26" apart. I don't know how well this will work out as we are still finishing the trailer. The whole teardrop sure moves as a solid single unit though. You can see my chassis plan by clicking the thread below. Sounds like you're on track though!
All the best,
Dave
DMcCam
Postby Wolffarmer » Sun Oct 21, 2012 2:00 pm
12 3/8' bolts are about 6 more than is needed. As long as the sides and top is firmly attached to the floor that is then bolted to the frame.
Be sure to use Grade 5 or better bolts.
Randy
Wolffarmer
Images: 309
